1 - 1 of 1 Posts
Hello Folks,
I installed a BBK (1843) 90mm throttle on my ‘18 DSRT. The “learn” procedure in the install went like this:
Disconnect Battery Negative
Install Throttle
Reconnect Battery
Turn Car to RUN
Slowly depress throttle 3 times top to bottom
Turn Car OFF
Done...
Think I had a backfire yesterday so trying to see what may of been the cause. The throttle has been on for about 3 days with no issues, assumed BF was with cruise control in on the highway with a slight downgrade and the motor in the 4cyl mode...
Although the above would make me think it Reset the PCM the pulling CB technique seems a bit different... getting in and waiting for the 2 (or 3) beeps from the car.
Comments or suggestions?
Cheers
1 - 1 of 1 Posts
