1 - 12 of 12 Posts
hello gents
i want to know what is the correct belt size for
1- ATI 10% Super Damper Balancer with 3.10 metco upper
2- ATI 10% Super Damper Balancer with 2.75 metro upper
with 2.75 pulley i think is i am not sure K100594HD , but with 3.10 i don't know which belt size should i order ?
also do i need idler or jest the belt ?
thanks
I’m trying to find out the belt needed for this setup
Litens 2.85 upper
ATI 10% OD lower
FI SC spacer plates
Thx
2019 Charger Hellcat
Litens 2.85 upper
ATI 10% OD lower
FI SC spacer plates
Thx
I think [mention]GreenMachine15 [/mention] can possibly help you
@catdaddy. He was able to help thank you for the response!
Reactions: CatDaddyB5
BigEvil, What was the belt size and was it a Bando belt? Also, was the tensioner mark set dead center or was it off a bit either on the tight or loose side. I've been through hell trying to get the right belt for the same set up. 4 Belts later and still a no go. They've all been too long or too short by a lot, I've even talked to Bando directly. I'd like the exact belt size that put the tensioner mark dead center if that makes sense. My Green belt is close but Litens says not to use the green belt use the Bando for whatever reason. Appreciate any info you can help with.
1 - 12 of 12 Posts
