Car is only out in nice sunny days. I live about an hour from the drag strip and will be driving to the track. I was leaning towards the Street R 315/50 but wanted others inputThat's what I do. I have good street tires for the street and bolt on my 17" MT street R's for the track. The OP wants to know a 17" drag radial for both street and strip so most likely the MT S/S will best serve that purpose.
Not sure if it's his daily or if he drives in the rain with the car or what.
Any fit issues? No rubbing anywhere?I run the Mickey Thompson 315/50/17 ET Street R's on my Super Stock. They Hook great and drive really nice on the street. View attachment 592457
They fit great. Plenty of clearance everywhere. Just mounted them up on the billet specialties bead locks and bolted them on. No modifications at all. There not even close to end links so didn't have to change those either. The billet specialties are 17x10 so yours being 17x11 you may need to change you're end links but not sure.Any fit issues? No rubbing anywhere?
I have a set of Bwoody links. I was more concerned of the clearance to wheel lip under hard launch. Looking at yours appears to be lots of clearance still 👍🏼They fit great. Plenty of clearance everywhere. Just mounted them up on the billet specialties bead locks and bolted them on. No modifications at all. There not even close to end links so didn't have to change those either. The billet specialties are 17x10 so yours being 17x11 you may need to change you're end links but not sure.
Then go with the Street R's. Only reason I recommend the S/S is because they handle rain decently just incase while giving you good dry grip hence the "Street/Strip" well rounded combo.Car is only out in nice sunny days. I live about an the drag strip and will be driving to the track. I was leaning towards the Street R 315/50 but wanted others input
My 60ft was a 1.48 last time at track. My car only had 450 miles on it then so wasn’t leaving super hard. Planning on hitting it much harder next track day. No signs of any rubbing anywhere.I have a set of Bwoody links. I was more concerned of the clearance to wheel lip under hard launch. Looking at yours appears to be lots of clearance still 👍🏼
What gear is in your car?Car is only out in nice sunny days. I live about an the drag strip and will be driving to the track. I was leaning towards the Street R 315/50 but wanted others input
That’s a good point. My car is 3.09 so they work good but if his is a 2.62 probably be to much tire.What gear is in your car?
Those tires are over 30” tall
Not with the wheels he bought… they only have 6” of back space so 315 would clearI think that size tire is going to rub on the inside of the wheel wells, requiring pounding of the ribs, and reforming the liner with heat.
3.09What gear is in your car?
I just searched, I guess you’re right.They do not make that light truck tire in a 20 as far as I know. Do they? That’s a short tire in a 18. Better off w a m&h imo as mickey isn’t making the matching street et fronts anymore
You might want to consider some supporting mods for back of your car. Otherwise everything is gonna be moving around and you could very possibly break the diff driveshaft or axles
