1 - 20 of 39 Posts
Hey guys, what’s the best intake you can get for a 2015 challenger hellcat? Looking for performance gains. Sucks I have the maf sensor and the power steering pump, so the new ones for redeyes and 2017+ are out of the question. Thanks!
· DRIVESRT.COM
· DRIVESRT.COM
· DRIVESRT.COM
is the JLT any good?
Filter Surface area and inlet tube on the JLT are more restrictive compared to other available options out there.
JLT
Filter: 8-layer S&B - 4 flange (circle), 5.5 top (circle), 7 base (circle), 7 height
Tube to TBody: Composite Plastic, 15.89 to 10.29 sq-in
Filter Surface Area: ~137 sq-in
aFe Stage 2 (2015+)
Filter: 5-layer Pro5R - 7.13 flange (circle), 7 top (circle), 8.75 base (rounded-square), 6.75 height, 4b x 2.5t x 2h inverse velocity stack
Tube to TBody: Composite Plastic, 39.9 to 10.29 sq-in
Filter Surface Area: ~158-206 sq-in (filter flow restricted to ~158 sq-in (~48 sq-in restriction) with rain shield installed)
Legmaker (2015+)
Filter: 8-layer S&B - 6 flange (circle), 5.25 top (circle), 7.5 base (circle), 7 height, 3.5b x 1.5t x 2.5h inverse velocity stack
Tube to TBody: Carbon Fiber, 28.26 to 10.29 sq-in
Filter Surface Area: ~160 sq-in
A Van Down by the River
AFE MAGNUM FORCE STAGE-2 PRO 5R COLD AIR INTAKE
Reactions: Octanewide
Any threads on upgrading to the dual headlight intake from a 2018 HC from the single headlight intake on the 2016?
I've never heard of such a thing...oem dual intakes through the headlights. I don't think so???
D/S only as far as I know. The 2019's and up have that dual intake hood, but that's not what we are talking about. Someone will be along shortly to clear it all up I'm sure...Getting back to the OP's question, JLT here as well.
Reactions: Unholy707
I removed the plug on my passenger side headlight just for some added airflow into the engine bay in hopes to help cool it some at speed. Probably worthless but it only takes 3 mins to take it off or put it on.
I went with the JLT more for sound than performance. Disappointed with the gap ot jad over the tube and how the rain shield blocks the drivers side vent. Made an additional piece for over the tube and modified an AFE shield for water concerns.
Bwoody makes a great CAI, looks and functions great and the whine is amazing too.
- Alexis
1 - 20 of 39 Posts
