Has anyone tried 93 mogas from an airport was wondering
if its good for cars no alcohol not sure what else is in it?
Yes, but is 91 at elevation equivalent to 93 for a 93 tune re knock prevention? Would I dare go to a 7% OD damper with stock tune on only 91 even at elevation?At elevation 91 is much better than 91 at sea lvl.
There’s an amazing thread on this on the other forums over at the other Hellcat forums.Yes, but is 91 at elevation equivalent to 93 for a 93 tune re knock prevention? Would I dare go to a 7% OD damper with stock tune on only 91 even at elevation?
MMX sells a 7% OD lower dampener that claims it runs fine on the stock tune, so no PCM unlocking required. If it's already pulling timing on the stock 93 tune because it's so aggressive, the 7% OD would likely require it to pull even more timing. Add in only 91 and it gets exacerbated even more--unless the altitude really does compensate for it, then it's back to the original problem of how much timing still gets pulled with the stock tune and 7% OD added...I have had more than 1 Super charged motor and not sure what your asking?
I had a 93 tune on a Vortex SC formula and had to run 91 from Kansas to Wa state and had no issues.
Is your tune for 93 at 4kfeet than no.
If your tune is at sea level I would have no issue running 91 to cross an area. If I lived at altitude I would ask the tuner... or have it tuned at altitude.
They claim the same thing for the 3.17 upper pulley--that it's mild enough it can run safely with the stock tune. Only adds about 2lbs of boost, about 25-30HP bump.Oh.. let me change my answer... I would not drive on 93 with a pulley unless it was tuned.
