461 - 480 of 1,026 Posts
Hopefully someone has had good weather and has installed the blower plate set up and has track results.
Mean Cat or anyone else, is there posted results from the track?
Maybe this set-up is good for Daily Driving?
Linda :)
Hey Linda mine should be done this weekend and then off to Rockingham for MSHS fri/sat so I will let you know how good they work. Danny
Thanks Danny
I'll see you at the Rock!:cool:
Linda :)
Carefully remove #2 (mine came off, it didn't just slide back like the illustration shows), then push the connection forward (toward super charger) and press in on #1, you should then be able to easily pull the assembly off the fuel rail. Use a rag under the connection point, gas will leak out.
Thanks! I’ll give that a go tomorrow.
For anyone that is worried about draining coolant and getting air in the system don’t worry. There is a bleeder screw on the back left side as you look at it, just above the inter cooler lines. Not sure if people are aware of that.
Thank you for this! Took my fear of dealing with the coolant away.
Last night at the Track - results with S/C Spacers , I am so stoked at the results , new PB 10.60 at 1300 DA , had passes of 10.60 , 10.61 & 10.62 ; the last time at the track it was 1400 DA so very similar to this time & had a best pass of 10.85 with other passes of 10.87, 10.88 , & 10.89 . So I basically gained 2.5 tenths at same DA .
PB 60' also 1.60 on 20" DR.
The 1/4 MPH was not reading rite on 2 of the 3 passes but it had 130.87 mph on that 1 pass. Previous PB was 10.70 & 10.71at 76 & -190 DA.
And I was chopping down the Tree last night too, it was a awesome night in not so good DA.
The only thing that was added was the S/C Spacers , a big shout to FI ( Kirk ) for a great product & to KG. ( Jeff ) for all your help to me & everyone else, I know all that mailing & put kits together is PITA.
Man , I wish I had some -1000 DA , I have no doubt it mite hit 10.4's.
Last night at the Track - results with S/C Spacers , I am so stoked at the results , new PB 10.60 at 1300 DA , had passes of 10.60 , 10.61 & 10.62 ; the last time at the track it was 1400 DA so very similar to this time & had a best pass of 10.85 with other passes of 10.87, 10.88 , & 10.89 . So I basically gained 2.5 tenths & same DA .
And tags of Useful, and certainly Winner too
Congrats are in order for your new pb:cool::cool::cool:
Thanks for sharing your results. Very interesting. Now I can't wait to try them myself.
