1 - 5 of 5 Posts
BMR Drag Pack. Bought in mid 2020, only have a few thousand miles. Worked effortlessly on the strip. SOLD. Will clean up before packing.
Hey man, where did you get it? Did you have to modify anything to use it? What car did you put it on?
I have heard a little about the “ drag pack” but don’t know much about it. Sounds like a good deal if I can use it
Hey. I got everything brand new from BMR. No modding. 16 Challenger HC 800whp.
isn’t it basically just good beefed up parts with some adjustments built into it…there isn’t any difference between this and using it to just strengthen the rear end no matter what type of driving your doing correct, ? If so then It wouldn’t hurt the road manners if your wanting it to handle better without breaking correct, ? Or does it have a certain amount of alignment angle changes built in which lend its self to straight line performance over all around performance or corner handling, ?
Discussion Starter · #5 ·
In short yes, beefier than oem, less flex and likelihood of breaking. I wanted to lower my car so It need the adjustability to get alignment back into spec. Single adj is stronger than their on-car adjustable.
1 - 5 of 5 Posts
