I haven’t , that’s why I’m asking. I saw people had issues with the upper adjustable ones, I’m asking about the lower trailing arms specifically. 100 vs $1500, big difference thereHave heard many say that the BMR's have failed , bent, broke @ adjusting point...AAD might be more expensive, but you will not have to worry about them failing.
Definitely a price difference but the AAD are $379.00 vs $110.00 for the lower trailing arms only.I haven’t , that’s why I’m asking. I saw people had issues with the upper adjustable ones, I’m asking about the lower trailing arms specifically. 100 vs $1500, big difference there
I’m not going to lock the diff, going to use p4d front diff brace and rear diff brace. Should tighten it upI doubt it’s the stock control arm that flexes… look at the stock ends (bushings). I could tell bmr ‘in car’ adj ends were weak in the pix. No need to search a forum ha. If I were you I would lock the diff before buying arms.
Do like I did n have a buddy super slo mo it for you ar the track
