1 - 13 of 13 Posts
SRT Durango Hellcat
The Durango HellCat brakes are just like the ones on my Challenger HellCat, the DUST IS TERRIBLE!!! We drove to a car cruise the other night, 20 miles and the front wheels were covered with dust ONCE AGAIN!! I checked with PowerStop(The pads I put on the Challenger) and they said the did not have any for it being a 2021, Too New. WELL, with a little research, found out they are the same as the 2020 TrackHawk. Just installed them today..... I installed the Z36 pads because I will be pulling the enclosed trailer with this Bad-Boy.
Well, NO MORE!!! The PowerStop pads are Excellent!!! 90% less dust and I didn't notice ANY reduction in stopping power on the Challenger. Highly Recommend them for Any car with this Problem!! ALSO, for those of you (Like Me) with a bad back, I started using the red motorcycle jack to support those big tires while removing and installing them. Just roll it up on the jack and slide it into place!!
Automotive tire Motor vehicle Alloy wheel Bumper Automotive design
Wheel Light Automotive tire Vehicle brake Automotive design
Tire Wheel Automotive tire Motor vehicle Automotive design
Automotive tire Automotive lighting Tire Vehicle Bumper
Tire Automotive tire Motor vehicle Wheel Automotive exterior
Tire Wheel Vehicle Automotive tire Automotive lighting
Wheel Tire Locking hubs Automotive tire Vehicle brake
Vehicle Car Automotive tire Automotive lighting Hood
is same problem.
View attachment 576516 View attachment 576517 View attachment 576518 View attachment 576519 View attachment 576520 View attachment 576521 View attachment 576522 View attachment 576523 is same problem.
Your pics bring back awful memories. Since installing the Powerstops on mine, I'd forgotten how thick a film the brembos can create. And I'll add that Graphene coating your wheels is the stuff of GODS! Just spraying the wheels with water gets them mostly clean.
2021 Durango SRT Hellcat
Did you do both front and rears, with the Trackhawk part numbers ?
Durango Hellcat
A reduction in dust means a reduction in performance, no way around it. Brembo & FCA spec'd those pads for a reason.. For a 5,700 lb SUV that could be pulling 8,700 lbs I'll take all the braking performance I can get. Ceramic coat your wheels, clean them thoroughly once a week, and use the paddles to downshift to slow down without using the brakes when possible.
Side note, the factory wheel and tire combo weighs 76 lbs.
576645
I hadn't thought of using a motorcycle jack! On another forum this week I started a discussion about using self-loading wheel dollies to change tires, but I like this idea too. Thanks!
Fast forward 30 seconds to get past the disclaimer.
2015 Charger SRT Hellcat
I watched Boyd's show, American Hot Rod, and learned a trick from a younger girl on the show (until Jo felt threatened).... She would sit on the ground, and lift the wheel into place with her knees/shins, then slide it on. I've used that method ever since and love it.
1 - 13 of 13 Posts
