1 - 4 of 4 Posts
Scratched my grey Brembo calipers, does anyone know of a touch up that is close?
HOTM Winner
believe it or not, many common enamels will work, if its just a scratch fill.
Ive had real good luck mixing/matching for various touch up on this & that, with testors model paint. plus its stupid cheap and easy avail, so it cost next to nothing to play around with. They have several military/aircraft gray's that are/can be made to be darn close.
I've used the little cans of Duplicolor caliper paint, and they are real close. Plus, they are inexpensive too.
As 18widecat said, use model enamel. Take a well-lit picture with you of the caliper and go to a local model shop. They will have hundreds of colors to pick from, you should be able to find a perfect match without even having to mix. I found a perfect match to the factory red Brembos that I use on mine. clean the area with alcohol or brake cleaner to remove any oils or dirt and use a small model paintbrush to touch up any scratches. So far the few little marks I touched up are still looking great 3 to 4 months later. You would have to get out a magnifying glass and look very closely to locate them.
1 - 4 of 4 Posts
