141 - 150 of 150 Posts
They work fine.
Hmmm, ok thanks. I've tried to pull the build status with no luck. Last update I got from the dealer was D1, it should still be able to locate it, right?
Sent from my SM-G935P using Tapatalk
What message are you getting?
"No records found corresponding to the VIN provided"
However, I have a screen shot from the dealer with the car's info in D1 status as of the last update from them.
Sorry, nothing will show up until car is built.
When car is built then the build sheet will show up.
Soon after the car goes KZ and is released by the plant then the window sticker will show up.
You can use this one too ..
COMPLETE VIN
ALL CAPS
Ok, thanks! So until the build is complete, the only way to continue getting updates is to keep bugging the dealer?
Yes that is correct, hang in there!
