Hey guys here’s my 2020 Hellcat Redeye.. “GOKU”
(Yes the banana is coming off) lol
As for the build, the car is currently set up on pump E85 that averages here Dallas near me around 83-87%.
Its primarily a street car that is sometimes raced at the track. (2 to 4 times a quarter) I’m not planing on taking it down to Mexico on a regular basis either if you catch my drift. Lol
The build process has already started by Bailys Hyperformance, I’m wanting to share data points of the journey here with the group.
As seen above the engine has already come out and we started the build in November, it will be a fully forged 426 stroker kit on the 6.2 Redeye engine.
The Build:
- 426 Stroker with forged Bolts, rods, pistons, and the crank.
- We are going with an upgraded cam (Bailys shop cam)
- We are porting the stock heads. Upgrading lifters, and all bottom end engine components.
- I went with the Magnuson TVS 2650 with upgrades to the front and rear cog pulleys. (I’ve also decided to go with the Big John Racing dual idler pulley)
- The car has a Legmaker Intake but adding a 108mm Kong Throttle body.
- Also adding a spacer to the blower intercooler.
- Running Kooks 3in SS Long tube headers, cat less mids, and exhaust. (Not sure what the back pressure will be as a 3in all the way back but I guess we’ll see)
- For fuel it hasn’t been fully decided yet because it’s based on our tuner but FIC 1700cc or 2000cc injectors. (No nitrous right now but it’s going to be added in the future)
- The fuel system that’s going to be ran is the FORE triple fuel pump system.
- With all of this air to combat heat, we’re going with a Stage two power chiller to upgrade the AC lines and factory power chiller and a 160 thermostat.
ALSO this might be over kill but it will have an ice tank in the trunk because I can’t be to
- The transmission is getting fully built to help out with all the extra torque, and we went with a 4 inch aluminum driveshaft rated up to 1400whp.
- As for the rear end, the subframe bushing have been upgraded front and rear, and performance development differential brace is covering the 3.09 gears.
- The axles have all been upgraded to 1400whp even though I’m sure at the track they may still break eventually.
- And Finally as for the Suspension, all control arms, and supporting has been upgraded to the fixed BWoody versions.
- The car WILL have a roll cage, rear seat deleted and 325/30r20 r888r Toyo’s while away from the track, and rolling Welds Racing Beedlocks 17x11 on 345 Mickey Thompson 50 inch side wall at the track.
Guys I’m so excited on this build and I can’t wait to share the end result. As I get more information I’ll do my best to share it along the way both here and Youtube. As said earlier, this car is being built by Chris over there at Bailys Hyperformance her in the DFW, Texas area and the tuning is being done by Curt Dusterhoff Tuning.
I have no freaking idea what this thing is going to make, however I’d like to be pushing on Race E85 at that 1400 whp and similar torque. The goal is fastest Redeye but I guess we’ll see. The car is about a month away from being done then the tuning should start.
Hope everyone enjoys the rest of their 2020, and let’s jump into this 2021 head first!
