I have a 2022 Charger HC with 2k miles on the clock. I just noticed that in the last 50 miles or so it will shake at idle when started or sitting at a stop light. It is worse when cold. I first thought it was a fuel issue so I ran some heet through it and topped it off with the best fuel I could find. I always run premium in it and took it easier during the break in period. I daily drive the car and don’t beat on it. The fuel didn’t make a difference. The tach is dead straight at idle. There’s no sputtering or knocking of any kind and the engine seems balanced and running smooth. It drives perfect.
I have noticed if I manually shift from 1 to 2 while stopped it makes a slight lurch/bump while stopped. I had the dealer reset the PCM and it didn’t make any change. I’m about to bring it back in again, does anyone have an idea on what it could be? I’m thinking something transmission related but I’m no mechanic or engineer. Thanks!
