I run a killer chiller, my IAT's start at 80 and never get above 111. This is perfect because timing won't be pulled. I/C coolant never gets above 70 on a hard pull at the track. Ran 9.6 last week on a hot lap.
Yeah, but you see all the condensation those chillers generate on aluminum. The placement of the bmr tank is bad imo with use of anything, especially a chiller, because you’ll be dropping water from condensation directly on the coil packs and wiring/connectors under itVery nice. For 1/4 mile racing, it's pretty clear that some kind of interchiller is the most predictable, effective, and straightforward way to go. Install really isn't any worse than the race HE, with all the trimming of the fascia you have to do with the HE.
I think that larger BMR tank really helps to keep those temps low through the whole run with the chiller. Gotta have that reserve of supercooled fluid.
I will have to see what my IAT's hit at the end of the track (1/8 mile) when racing starts this year.
Yes, I've read that, but this was the only option. I've talked quite a bit to the guy who has that site as he's a mustang guy, and he told me that he does plan to make a kit for the hellcat eventually. The big thing he emphasizes is the importance of water speed and also inlet and outlet sizes of the HE and also the intercooler, and as large of hoses as you can run, like 1.25". The bwoody also should have bigger ports.From what I've read the 3.5 core is too thick. (I don't know how accurate this info is so take it with a grain of salt)
Heat Exchanger Size-Tech Information S197 - Department of Boost
www.departmentofboost.com
I am not running ice in mine, and no interchiller. I am just trying to increase coolant capacity, which this does, by a little under 1.5 gallons, which is a lot considering how little coolant is actually in the stock system. I have adhesive heat material around the box. It stays cool, and no issues with condensation of course using it the way that I am. But I see how that would be a problem with running ice or interchiller.Yeah, but you see all the condensation those chillers generate on aluminum. The placement of the bmr tank is bad imo with use of anything, especially a chiller, because you’ll be dropping water from condensation directly on the coil packs and wiring/connectors under it
The trunk is a bad idea. Takes way too long to get back there and up front. If you runner a chiller, never do a trunk ice tankAnother obvious negative with the BMR reservoir is it has to be removed to get to the coils and spark plugs. However, I will just suck the fluid out of it and then I have AN fittings for everything, and I also have AN caps and plugs to put on all the lines and on the reservoir itself.
So it will be a pain. But I'd still rather do it this way than have something in the trunk. There isn't really room anywhere along the front bumper since the stock HE is on the DS and the oil cooler is on the PS.
Line the front of the tank (EDIT: COOLER, NOT TANK) with a series of all-environment Noctua cooling fans that can be switched on via thermostat or manually? Or put them behind. Noctuas don't care. They are top-of-the-line computer cooling fans, and the industrial ones can REALLY flow the air and are splash-proof.From what I've read the 3.5 core is too thick. (I don't know how accurate this info is so take it with a grain of salt)
Thick/Tight Cores Are A Problem:
Through testing we have learned that once cores get thicker than 2.625” they’re too thick to efficiently pass air though them. As an extreme example we have tested a 2.65” core vs a 3.125” core. The 3.125” core had half the airflow of the 2.65”. So yes, core size/volume is very important. But only if that volume is attained without making it too thick.
That same company said cooling fans don't help and actually hurt airflow above 40mph. There is no room for them in any case there is barely enough room for the cooler.Line the front of the tank with a series of all-environment Noctua cooling fans that can be switched on via thermostat or manually? Or put them behind. Noctuas don't care. They are top-of-the-line computer cooling fans, and the industrial ones can REALLY flow the air and are splash-proof.
It’s a ball cooler - all hellcat owners have huge ballsLine the front of the tank with a series of all-environment Noctua cooling fans that can be switched on via thermostat or manually? Or put them behind. Noctuas don't care. They are top-of-the-line computer cooling fans, and the industrial ones can REALLY flow the air and are splash-proof.
I kind of want one, I don’t know. Going to change the plugs again soon, maybe I’ll do them before I get the tank lolAnother obvious negative with the BMR reservoir is it has to be removed to get to the coils and spark plugs. However, I will just suck the fluid out of it and then I have AN fittings for everything, and I also have AN caps and plugs to put on all the lines and on the reservoir itself.
What I find hard to believe is that the thicker cooler would somehow lack airflow in the first place. Have you noticed it fails to cool in any sense?That same company said cooling fans don't help and actually hurt airflow above 40mph. There is no room for them in any case there is barely enough room for the cooler.
very theoretical there…Yeah, but you see all the condensation those chillers generate on aluminum. The placement of the bmr tank is bad imo with use of anything, especially a chiller, because you’ll be dropping water from condensation directly on the coil packs and wiring/connectors under it
It’s not theoretical, it’s physics. The aluminum will be so cold from dipping below freezing / at freezing from the interchiller condensation from the air will collect and freeze on it. Do you have a killer chiller?very theoretical there…
factual: havent seen condensation anywhere on them or on the ground.
