1 - 20 of 21 Posts
Have Guns Will Travel
Nice.
Very nice vid. Simple and helpful.
I'm just starting to learn about some of these mods. Installing Bwoody CAI tomorrow assuming it arrives. Is this something I could add next? Looks like I just need to order the "BWoody Hellcat Anti-Slip idler Pulley" and then I need to get the belt, what belt should I get?
Discussion Starter #6
Nice!Your running the 2.5 pulley?What size belt are you running?
I need to check the part number for you but its the belt that works with the 2.75 and 2.85" pulley,ill check tomorrow for you,thanks for checking out the vid.
Discussion Starter #7
If you are on the stock pulley then you probably dont need the bwoody idler pulley but you can always call Mike over at Bwoody Performance and he will let you know for sure.
Kool.I am running the ATI lower and 2.65 upper but want to switch to the 2.5 upper.ordered the pulley as I already lost a belt(and tensioner's,both belts actually,alternator and a nasty divot in the supercharger:().
How did that happen? From the mods?
Sizzle
Thanks for posting, how much boost are you seeing now running the 2.50 and the "bwoody idler pulley?
Running a 2.65 pulley and stock lower pulley, is the anti slip idler recommended? I'd like to stay stick looking as possible. Then again, not many people have seen under the hood of a hellcat, so an additional pulley may not be a dead give away to most.
are you experiencing any belt slippage? any black dust around belt and supercharger snout?
It's not on yet.
Guess I would rather strip down a belt than spin a crank I'm not going to pin....
I have a small amount of black dust around the snout and the belt is slightly black on the inside and outside edge. Does this indicate belt slip? I'm running the 2.75 and gates 572 belt.
yes it does indicate slippage
Have y'all tried belt dressing?
It's a little messy, but, will stop the slip for a while. We use it on our big equipment.
yea helps for about 2 dyno pulls, not a permanent fix.
1 - 20 of 21 Posts
