1 - 2 of 2 Posts
Recently I damaged the front end on my driver side in my charger I replaced the driver side strut the control arms and the subframe after labor and installation I noticed a camber on my driver side, thinking it was structural damage I took it to a frame straightening shop only to be told my frame is intact but my strut is the reason why the wheel is cambering im thinking maybe if I reset the active damping system it wil sort itself out, seeing as I never reset it in the first place. Has anyone had this issue? And how can I reset the system myself without having to come out of pocket if it’s possible? I’ve added a couple pics to show the space between the control arm and the strut the latter picture is the the front driver side where the problem exists
Automotive tire Motor vehicle Electrical wiring Gas Electricity
By the painted-on number, I am guessing you saved a few dollars by buying a used strut. That would be my first suspect. Best bet is an SRT or Dodge garage, as they will have the exact factory measurements, etc, won't they?
1 - 2 of 2 Posts
