The impellers are slowing down, like a turbine.
@baabootoo cool so do you think everything’s ok ?The impellers are slowing down, like a turbine.
I’ll take it to the dealer and try to get it done thanks 🙏🏼Also, If you had the recommended recall last year, they did not program the shutdown sequence correctly, there is another recall to fix THAT recall. My car sounded like it was passing gas when it shut down.
Do you think this affects the performance of the car as well?I’ll take it to the dealer and try to get it done thanks 🙏🏼
Do you think it affects the performance of the car as well?Also, If you had the recommended recall last year, they did not program the shutdown sequence correctly, there is another recall to fix THAT recall. My car sounded like it was passing gas when it shut down.
Hi 520kW,Also, If you had the recommended recall last year, they did not program the shutdown sequence correctly, there is another recall to fix THAT recall. My car sounded like it was passing gas when it shut down.
Thanks I’ll take a lookHi 520kW,
You can use the link below to check for open recalls for your vehicle or send us a message via private message with your VIN.
Lookup FCA Vehicle Recalls by VIN | Official Mopar® Site
Search vehicle recall information by VIN or sign in to your Mopar account to see recall information related to your Chrysler, Dodge, Jeep, or Ram vehicle.www.mopar.com
Rob
Dodge Cares
I’m wondering the same I’m taking mine soon I’ll let you know what they sayDid anyone look at the winding down sound issue at a dealer?
