41 - 60 of 81 Posts
Not here! Mine is my daily driver all year. However, I do tend to drive the Miata more in Spring & Summer for obvious reasons. The Miata will be put away for winter & the winter wheel & tire setup will go on the Hellcat soon, though.
562576
I have another month. I do a thorough clean and put the cover on it. Once it gets so cold I don’t like to pull it out of the garage because it could get filthy and then it might be too cold to wash so I would have to stare at a dirty car for 3 months.
lol wtf? Use rinseless wash. I pretty much use it all year b/c it's so much easier & more convenient.
Here in Southern CT, the leaves are finally starting to change. I have at least 2 more months before I can even think about putting them away.
A few miles north of you...had my cat out today...still some favorable days for us coming up
Mine will be getting tucked away here soon. Colder weather will be sitting in soon here in Southern Illinois
Yup, same here on LI. I'll go into December if the roads have not yet been salted. After the first snow the cars get laid up, summer tires removed, detailed, and oil changed.
Not me :)
It all depends on where you live. Rinseless washing would never cut it in the winters we get. Then there's the salt. In a couple of weeks there will never not be salt on the roads here until next April...sometimes till mid May. In a month or so, most all subdivision / side roads will be snow covered till spring. Our HC would never even make it up our very slight incline 45' driveway. Finally, I'd much rather run through a touchless wash and finish drying it at home than the hassle of the rinseless process. To each his own :)
Plenty of snow & salt here It cuts it just fine. Hit up a car wash to get the undercarriage...
Mines all put away. I live in Chicago area but hunting season has started so by the time I get around to driving her again I would be the end of November. So battery tender is in and tires aired up.
what PSI did you bump it up to?
I'm guessing not near the snow or cold or maybe even salt? PA is way south of here. Apples and oranges. No comparison. We'll typically have a 100 inches of snow by the end of the year or early January. Car washes freeze up here in the cold weather. None have infloor underbody nozzles...only the side blaster set up. Lots of electronics on a HC to get buggered up by corrosion from salt damage. It's not possible to keep all the salt off a vehicle's underside here in the winter...or body for that matter.
41 - 60 of 81 Posts
