1 - 8 of 8 Posts
· HOTY Winner
Decided to make a switch panel from 1/16 cf sheet. Going to hold three 16a 19mm switches for 2-step, killer chiller bypass valve, and ac drag valve. I am just waiting on the switches, back-lit billet from Billet Automotive Buttons.
Automotive tire Hood Motor vehicle Tire Steering part
· HOTY Winner
I assume I will wire it for activation.
You aren't going to run it off pedal? You would have to switch it off to let the car get past the set limit, running it to activate off the brake pedal would just turn it on for that launch and then it would let you rev out.
I figured you would wire a power switch in your panel for it so when you want to do a burnout and don't have rpm interference.
· HOTY Winner
Discussion Starter · #6 ·
I am going to run it off the brake pedal, yes.
The switch will be to turn it on and use the two step. I am not driving with it on all the time.
Reactions: jakelind707
· HOTY Winner
Discussion Starter · #8 ·
Look on eblay.
It was like $8 for a thin 1/16 piece
1 - 8 of 8 Posts
