1 - 4 of 4 Posts
So I got tsp long tubes and high flow cats. The cats they give are junk so I'm getting cat below threshold on both banks. I did the spark plug non fouler trick but now I'm getting both downstream sensor high voltage. Used 2 foulers per sensor with one drilled out and the second one normal. I know some cars are weird and gotta do different stuff for it to work. Do I need to put steel wool in or drill the second one out bigger?
Hand Finger Household hardware Automotive tire Thumb
Household hardware Engineering Gas Nickel Auto part
I tried everything. You might get check for o2 to set as ready sometimes. As soon as you do a pull you'll gets codes. Antifoulers get rid of differential code. However, you will get voltage codes for it not changing fast enough or temp code out of the rear o2.
1 - 4 of 4 Posts
