Is there a trick to removing the centre console side panels. I'm starting to get the dreaded delamination on mine. I can get the narrow end towards the rear unclipped but I can't get the forward section to release. Any and all help appreciated.
Thanks. I knew there had to be something holding it because it was not giving it up. Gives me something to do this weekend. Going to try to repair it first before I drop the two bills on the replacement part.If they are like the challengers, you have to remove the shifter bezel, remove the two screws securing it frontwards to the dash, then remove the screws holding the side panels to the inner console structure. They made it much more complicated than it needed to be...
I can get the panel loose at the back end. I just can't get it to release at the front end. Any suggestions?On the Charger they just pop off. maybe try to contact @DodgeCares on here and see if they can escalate it with the dealership for you. Like the door panel warpage, this is a well known issue and you shouldn't have to foot the bill for a replacement part if your car isn't that old, or just out of warranty.
