I posted in late August about my DSS CF Driveshaft failure. The shaft broke on the 5th pass. The car is stock other than the 305 Mickeys on the back. The good new is it didn't damage a thing other than the insulation that lines the transmission tunnel. I got a hold of the DSS and they were great to deal with. Spoke with them on the phone and several e-mails back and forth. They warrantied the shaft no problem and got me out one within a week or so after they got my shaft. I asked what they thought happened and they said they weren't sure as they never had a stock car break one. They said it looked like a torque failure. The only thing I can attribute it too is I tried Launch control on the second pass and I couldn't hold the car. I can only assume it somehow partially fractured the shaft and just finally let go on the 5th pass. The new shaft is now installed and no issues.
The link below shows the install and shows the extent of the damage which was limited to the tunnel insulation. If anyone is contemplating doing the drive shaft themselves it's pretty easy to do as long as you have access to a lift. I know some have done it on jack stands... After installing this shaft twice I sure wouldn't want to do it laying on my back with the car on stands as it is kind of cramped quarters down there.
