I have a couple dozen single 52mm gauge pod vent inserts designed to fit the 2015+ Charger driver's side vent. This insert retains the factory on/off vent control functionality and still allows airflow around the gauge pod from the vent. It is a snap-in replacement that requires no cutting, glue, etc. Installation is simple and takes a matter of minutes. It is fully reversible if you decide to remove it and put the factory vent fins back into the vent. These are made from high quality black ABS plastic for both strength and temperature tolerance.
These are a great option for anyone who wants to run an ethanol content sensor and gauge while running flex fuel tunes/E85 tunes, aftermarket boost gauges, aftermarket wideband AFR gauges, etc. They're a much lower profile and cheaper option than replacement A-pillars with built-in gauge pods.
Price includes shipping to the continental US.
