1 - 3 of 3 Posts
Hi all! I live in Indiana and store my HC during the winter. I have a battery tender on it the car but the battery voltage is readying like 12.8. My race car is reading 14.4. My question: is there something putting a small load on the battery that I should be aware of?
2015 Charger SRT Hellcat
That is fine. I even did some research for you.
  • Including results for good battery voltage.
    Do you want results only for good battery volatge?
  • 12.6 volts
    • According to 3 sources
    What is a good battery voltage? The measure for fully charged automotive batteries should be at least 12.6 volts. When the engine is running, the measurement should be between 13 and 14.7%.
    homex.com
    What is a Good Voltage for a Car Battery? 12.6 volts is a good voltage when the engine is at rest. This voltage indicates that 12-volt automotive batteries are fully
  • 12.6 volts
  • What is a good battery voltage? The measure for fully charged automotive batteries should be at least 12.6 volts. When the engine is running, the measurement should be between 13 and 14.7%.
    homex.com
Thank you.
1 - 3 of 3 Posts
