You Hemi has ticks! The horror!That's a standard hemi tick , I've had 4 he is they all did it
engine at operating temp, 5 minutes after key off.I was taught that the most accurate time to check is when the engine is cold.
info I posted is from FSM. pretty sure they know what they're talking about.Not in the Hemi's. Takes a long time for all the oil to drain back to the sump. My last two were constantly getting overfilled because of that.
you're using the wrong techs.If I run the engine and check the oil in 5 minutes, then wait an hour and check it again there is almost a half quart difference in the level. Techs were consistently putting in 8 quarts instead of 7, when I insisted they only put 7 quarts in they'd write a note on the receipt that I left with the motor showing a half quart low. Next morning the level was right up to the top.
On the other hand if it's in the manual or on the Internet it must be true so I stand corrected.
Check your both ways and see for yourself.so whos right, dealer, or owner
My tech asked me when I called him when I checked the oil because it was 1.5 quarts low. I explained that I had driven it around town, came back waited probably 8-10 mins and checked. He said, yeah it might be low, bring it in. IExactly Jim, try it for yourself before people just make closed minded remarks. I honestly think some people saying they're a quart low at 300 miles is attributable to this.
1 qt every 1k miles is "normal"???? Crazy talk...Of the few initial problems reported with Hellcats, oil consumption is the one that troubles me. I sure hope this problem goes away after break-in. I have experienced an auto manufacture claiming 1 quart every 1K miles is “normal.”
fnky! Welcome to the forum! I remember you from lxforums and some other chrysler forums. I'm glad to see you've found us here, and we'll be able to benefit from your knowledge and access to tech info.you're using the wrong techs.
I'm not using anything besides the recommended Pennzoil Ultra Premium 0-40w synthetic. I am checking every 509. I'm definitely not worried about it.Keep a log book of every time you add oil and the type of oil. I would even keep the lot number and brand of the oil used. This will provide very important information if you have any oil related warranty claims. BMW has standards for appropriate oil consumption for their high output engines. One quart every 2,000 miles is not unusual for them and is considered normal and not excessive.
Just provided as a reference.
I am certain some Gen II hemis were using a quart every 1,000 miles. Cold starts are hard, hence why I ordered a block heater. Any time temp is below freezing, she will get plugged in.
Every 509 miles. Exactly...doesn't matter where I am, 509, I stop and wait 5 mins and check oil. LMAO! J/k. It was meant to say every 500. But the other would be kinda funny...Ummmm, whats 509.....
