17 Challenger SRT 392 M6 HRT stage 1 cam, kooks longtubes, 85mm TB
I've got a weird issue I'd like to bounce off some of your heads.
I've been having a weird intermittent issue with losing my clutch engagement point after getting on it for a bit.
I can't seem to put my finger on what's happening.
I'm not seeing any leaks anywhere.
It's works flawlessly under normal driving conditions.
No difference after flushing the brake fluid.
It doesn't bleed down if I stand on the clutch for a long period of time.
It doesn't do it if I shift quickly.
It only does it after WOT runs, so it may be RPM related somehow.
I might just swap out the master cylinder and see if anything changes.
I've done the CDV delete at 15k miles. I'm at 40k now.
2017 SRT 392
Symptoms are that the clutch doesn't disengage until closer to floor than normal. A few pumps of the pedal and it's back to normal.
I've noticed it most when dropping down and running through 2nd and 3rd. Sometimes to the point I miss 3rd gear because it won't engage.
Open to hear some thoughts or ideas for me to try or look into
Sent from my Pixel 5 using Tapatalk
2017 SRT 392
