If you attempt to capture the air from the center scoop for intake air it will be no colder than the air that enters through the hole next to the headlight.
What I like about this hood on the Hellcat is that it blows a steady stream of cold air across the supercharger lid, where THE hottest air is in the intake tract, JUST post-supercharger and before it gets to the aftercoolers.
One reason I like this car is that there are so many little things that are outstanding but can still be detailed to absolutely maximize them if one has the inclination.
There are so many fluids in so may places flowing through so many fittings and hoses. Optimizing those alone is a fun mental exercise. None of the pumps except the oil and air are positive-displacement, which means they only create pressure differentials, which means that any easing of the flow path results in an easier life for the pump and a higher rate of fluid flow.
I know the car is wonderful as it is, but all these fascinating little potential points for tiny improvements are very interesting to a small part of the population, of which I am part.
What the Challenger ALSO has is such a wide range of models and engines and drivetrains one can order, which allows one to order up exactly what one prefers, then, if so inclined, enjoy the process of turning it into exactly what one wants, even if this means going full-honk HHP and going for nines, eight, or whatever, or going for as much as you can wring out of the V6, taking advantage of its lower base weight, then going from there. AWD? 2WD? So many different means to so many different ends.
Sleepers? Over-the-top One-Car-Parades? You name it. Debadged, upbadged, downbadged, sidebadged, it's all there to do with as you please. A trunk-mounted hidden massively sound-muffled twin turbo system? There is plenty of room to hide it under there. I have a new invention that would help sleepers, but I have not patented it. How much stealth do you want? This car has the room to hide almost anything under the generously-proportioned skin.
Imagine a stock-looking Hellcat doing 8's. Imagine a stock-looking AWDmobile pulling 1.2 second 60-foot times. Some things are just fun to play with, mentally, even if they are not done that way in the end.
The only thing this baby doesn't offer yet is a DOHC turbo setup. Look at all that engine bay room. Imagine the fun of an obscene 3.0L inline-4 motor strapped to a giant turbo.
But, as usual, I digress. There is just so much on this car to like. The gasoline engine will not die. It will continue to thrive. It has not even reached half of its potential, yet, whereas the electric motor is almost done, as far as how much efficiency and power you can get out of it. Physics are physics.
This car has just been started, when it comes to various modifications, because it trounces most other cars so well, but over time, those who love every little detail will bring things to bear that keep inching it ever higher, just like the classic muscle cars. When they came out, headers, flat-tappets and gold-plated dual points were cool.
Then came cylinder heads. Then you were allowed to have raised ports in Pro Stock, as-cast, which was a revolution, as they used to have to build up a wedge of stick welding to angle the ports how they liked them, with 25 pounds of aluminum added to make the intake side of the heads higher than the exhaust side, then grind it flat.
Then, this as-cast raised-port configuration spilled into the mainstream with Brodix, the B1, and various other makes, and THEN the Big Three just started redesigning their engines to raise the ports right from the foundry.
Then fuel injection. Then port fuel injection, but those big V8s are still here, as will be the Hellcat and fam. They are not going to die no matter how much the governments of the world declare war on the people on whose behalf they claim to govern.
The future is bright, not only for the careful paint-mark-from-the-assembly-line-preserving collector but the most subtle to most obvious modification lovers.
If I were going to go the full race car route, I'd prefer a model other than the Hellcat or a body-in-white to start with, as I don't like defiling works of art, but, hey, once you buy it, it's your to do with as you wish.
