1 - 12 of 12 Posts
Had my 2019 redeye to a perf shop here in south Florida . Added their phase 1 kit.
They use a mustang Dyno.
Post install Dyno run Print out says 790 adjusted HP, apparently at the wheels ….
Adding 15 percent for the 8 speed automatic transmission gives me 908 HP at the flywheel?
car computer is showing up from 797 to 857…. Thoughts ?
· DRIVESRT.COM
Adding 15 percent for the manual transmission gives me 908 HP at the flywheel?
What was the baseline dyno and peak rpm?
What were the parts used in the phase 1 kit? 2.85 pulley, tune, fuel octane?
· Super Moderator
Jeep GC Trackhawk
Is a manual transmission part of the phase 1 kit?
Discussion Starter · #6 ·
There in lies part of the problem , a baseline was never done. I don’t see how I will know exactly how much I gained without a baseline. That being said estimations were used which is clearly not the way to do it but I had no choice.
The post install Dyno ran up to 6600 RPM.
The phase 1 included: the 2.85 pulley, larger injectors, “racing spark plugs”,170 degree thermostat, tune using my daily 93 octane fuel …
What gear was it in for the pull? What rear end gears? These can both affect whp. My SS is getting built now and the baseline pull was only 674 whp on a Mustang. That was in 5th gear (auto) and 3:09’s. It’s the delta that matters, but without a baseline you won’t know that. It’s also not just about the max hp. It’s the area under the curve that matters. A concave curve will beat a convex curve eight days a week, everything else being equal.
First, the "857" on the display doesn't really correlate to anything particular. It's just a string read out of the config file.
Second, 790 at the wheels for a comparatively small set of mods isn't terrible at all. Certainly enough to squash unmodded Mustangs, Camaros, some Porches...
Third, there's a whole swamp of debate on dyno types and results. Just remember that a dyno is just a tuning device...what matters is how it works for you!
Get out there and enjoy it! :cool:(y)
Discussion Starter · #9 ·
Thank you ….. I really go by the seat of my pants . My red eye stock I felt was a beast . I’ve had it to the track, and hustles pretty good. With those mods while I agree with you it was not a ton of things, I did find that I definitely felt a difference. I guess I was just trying to correlate all the numbers…..i love this car . My daily driver .
Discussion Starter · #10 ·
Appreciate the reply . They did not do a baseline … I suspect for a reason . The claim is 100 HP increase. With no baseline impossible to tell BUT I am happy with the shop . Fair pricing , answered all questions . Kept to their turn around promise , I feel the difference for sure .. I don’t have 309 option and I believe it was fifth gear… …
· DRIVESRT.COM
For a few estimations:
OEM 3.35 pulley, 700cc injectors, Bosch R6 spark plug, 203 tstat, 91 octane
Stock Redeye SAE: ~712 rwhp / 812 hp @ 6400 rpm = 12.3% drivetrain loss (87.7%)
Stock Redeye: ~ 698 rwhp / 797 hp @ 6300 rpm = 797 x .877
Stock Redeye: ~695 rwhp / 793 hp @ 6200 rpm = 793 x .877
Stock Redeye: ~17 rwhp / ~19 hp 200 rpm difference
Max engine speed: 6500 rpm
3.17 hellaphant pulley, 700cc injectors, Bosch R6 spark plug, 180 tstat, 91 octane
Direct Connection Stage II: ~734 rwhp / 837 hp (unknown rpm) = 837 x .877
2.85 pulley, larger injectors, "racing" spark plugs, 170 tstat, 93 octane
Modded SAE: 790 rwhp / 900 hp @ 6600 rpm = 790 / .877
Modded: 773 rwhp / 881 hp @ 6400 rpm = 790 - 17 and 900 - 19
Discussion Starter · #12 ·
3.17 hellaphant, 700cc injectors, Bosch R6 spark plug, 180 tstat, 91 octane
I now have my homework cut out for me … I look forward to crunching the numbers . Thank you very much for taking the time to post this info . Much appreciated !
1 - 12 of 12 Posts
