1 - 11 of 11 Posts
‘16 A8 Shaker
Road surface Asphalt Wood Font Headgear
If you are getting ready to install a cradle lockout (highly recommended when running a drag radial on a prepped surface) you may have read how removing the limiter plate is the hardest part of the installation. I made a tool that basically pops these right off. No drilling required. HMU if you want one
Gear puller type device? I drilled mine out so I’m just asking out of curiosity.
‘16 A8 Shaker
Discussion Starter · #4 ·
Naw tried that fist. Turned down a insert but couldn’t grab the plate w a puller so made a tool that removes almost all the press by slightly distorting the alum part
Tire Automotive tire Bicycle part Finger Bumper
‘16 A8 Shaker
Discussion Starter · #7 ·
If so get a 125mm long 13mm hex head bolt and a short piece of 1/2” pipe. Bevel the i.d. of the pipe about 40° so it moves the center of the bushing away from the limiter plate. I didn’t have any 1/2” pipe handy and wasn’t going back after already buying a puller that didn’t work. But I did have a 125mm bolt that was threaded full reach and a keps nut that fit it : )
I turned down the nut, reversed it, and when tightened against the center of the bushing it removed enough of the interference that I could easily pry the plate off
Automotive lighting Automotive tire Light Motor vehicle Rim
· HOTY Winner
Its a good idea rather than having to drill, I get it.
But the time it takes to drill it and get it off was less than 5 minutes per side. So fabbing a tool will take longer than just getting the job done IMHO.
I feel like if people had issues getting these off, they are not capable of making the tool either.
Appreciate the info regardless.
Reactions: OldMoparGuy
· HOTY Winner
Was your car on the ground or on a lift when you drilled them?
On a park lift.
It would have been easier if it was on jack stands and I could have been kneeling in the fenderwell. If someone is laying under it while they are drilling, they need to evaluate the job before starting the work.
And get a new cobalt drill bit, don't try to drill this with some old bit unless you love the punishment.
Had mine on jack stands with new bit and long assed crow bar. Piece of cake.
1 - 11 of 11 Posts
