1 - 15 of 15 Posts
Quick question has anyone put a 2018-2021 updated crankshaft bolt into a 2015 HC? I know it’s been updated and am going to pin the crank and was going to get the latest crank bolt. Little help will a newer on fit all the same just with different torque specs obviously.
Discussion Starter · #2 ·
577949
I thought the Demon ones were torque to yield?
Discussion Starter · #6 ·
Thanks Speedy
Discussion Starter · #7 ·
Confirmed, Demon bolt part # 6512335AA is what you want to use. Tq to 239 ft lbs
I thought the torque spec for the new bolt was lower, plus 150 degrees?
I’m going to pin the crank and update the bolt, basically the same thing you did in your video. I would rather have the extra insurance on the 2015, especially with the potential for the known issues.
· Administrator
The spec for the new bolt is 200nm or roughly 147 ft-lbs plus 150 degrees.
All the bolts are torque to yield. Just a different way to get there.
Just pinned my crank and replaced the crank bolt with the Demon bolt from HHP. They have it for $26.95. It’s 148 ft/lbs + 150 degrees
Reactions: OldMoparGuy
I used the original part number bolt with lock tite.
1 - 15 of 15 Posts
