In another post I talked about my car smacking a curb pretty hard. I replaced the knuckle hub assembly along with all the control arms/linkage. I need an alignment to correct my steering wheel, but it drives straight. I believe my subframe shifted over. I will address that after my alignment. My question is about the 3 codes I have: ESP, ABS, and Active Damping System. My strut shroud got wheel rub, but doesn't look like the strut is damaged. Do these codes just need to be reset/flashed, or is there likely damage to some wiring. I have almost ZERO trust for any autobody places, especially the dealerships (I used tobwprk at one).
16 hellcat charger
Thank you
Joe
16 hellcat charger
Thank you
Joe
