1 - 10 of 10 Posts
I just ordered Demon injectors and installed them today, once installed some of the injectors leaked, I believe they are all seated, does anybody know if the stock clips for the injectors are needed with the demon ones?
Thanks John
Did you apply a dab of grease to the orings? I put a set in dry once and it distorted the orings and a few leaked .
Thanks John
The clips do not prevent a leak. They are there purely for assembly purposes. If you have a leak now perhaps the injectors are not seated in the manifold or rail holes fully or some of the orings rolled or were cut in installation.
Discussion Starter #5
the o rings all looked ok with no cuts, the install went smoothly otherwise and its just my front driver's side injector that is leaking the other side was completely fine.
it didnt come with any grease
Do you have any ? You don't need much just a skin on each oring. I would pull them all out and apply grease the gently seat them in. I think you will be OK
I have also used just a fingertip of new engine oil on injector orings before. You just want to lube them to help prevent rolling.
1 - 10 of 10 Posts
