I’m due for a pair of front rotors for my Hellcat. I figure since the prices of the front Demon performance rotors aren’t too far off from the prices of the front oem rotors I found online… I might consider them for the benefit of less rotational and unprung weight. I will most likely only purchase the "front" Demon performance rotors and keep the rear oem rotors since the “rear” Demon performance rotors are quite a bit more pricey than the “rear” oem rotors and I don’t think it’s worth the weight savings per cost for the rear DP rotors. I’m not too familiar with the Demon performance brake setup but I will purchase the factory brake pads from Brembo directly. I have a few curious questions if you all don’t mind.
1. Has anyone had a set of front Demon performance rotors on their cars and noticed any difference compared to the oem rotors?
2. Are they worth the change or better off just stick with the oem rotors?
3. Any downsides to the Demon performance rotors that I should know about? For example, do they not last as long as the oem rotors and you wind up purchasing them more often as you would compare to the factory rotors on our cars?
4. Before I purchase the front Demon performance rotors, I found two links that sell them and are similar in price but I’m curious to know if that includes everything that I need to purchase and if there are no other additional items or parts that are needed? Here are the links below for reference.
Demon Performance 2 Piece Rotors - Dodge Hellcat Performance Brake Rotors
Demon 2-Piece Front Brake Rotor Set 2015-2020 Challenger/Charger 6-Piston
5. I found the Demon performance rotors here in this link a little cheaper than the two above links I posted but I’m curious to know if it’s because there are other added items you have to purchase along with it to increase the total cost or it just so happens to be cheaper?
Demon Performance Rotors: 15-20 Dodge Challenger / Charger, Challenger Hellcat/ Redeye | BWP Automotive Concepts
Please let me know your experiences with the Demon performance rotors. My Hellcat is my daily driver and I take it to the drag strip pretty often so I wonder if the little bit of weight reduction might make a difference at the track or in general. Thank you and I look forward in hearing from you all.
