Diablosport suspension controller
84690 Views 567 Replies 70 Participants Last post by  HemiAction
What does everyone think of this? I'm curious as to whether or not this decreases shock life more than normal, what the cost of the controller will be & actual proof of handling improvement. Saw their video & all it showed was cars launching. Nothing with street driving or road course...
301 - 320 of 568 Posts
Rayzazoo,
Thanks for the post and for digging into the numbers.
This sounds like we're getting somewhere - listing distinctions in OEM settings for starters.
Do the DSC/DiabloSport controllers similarly ramp up base starting firmness for the three selectable modes? Is that all it does, or is there additional tuning for anticipated standing start launches and braking forces?
One consistent observation is that when braking the controller senses weight transfer towards the front and firms up the front shocks. That has to be a matter of enabling the controller to sense longitudinal G forces and if it can do that then programming it to do the opposite - allow more rear shock compression and perhaps more front shock extension too - during hard launches or rolling launches - would be a great way to get more wheel downforce on the rear wheels to help avoid spinning the tires.
For initially turning, is there a customized for the Challenger's weight, springs and shocks (predicted body roll), change in individual wheel shock firmness?
It sounds like, since you used Track as your straight ahead example, that the DSC controller in Track mode would be in firmest base ride 100mA in all four corners (like OEM), then sense a bump in one wheel so quickly it could go into OEM Street mode's 400mA softer ride response to absorb the bump and keep the wheel in ground contact, then quickly go back into 100mA in all four corners past the bump. Is this correct? If so, this is a big improvement over OEM Track mode.
But, if the above IS true for Track, and perhaps Sport mode as well with its base 200mA setting, why would anyone ever want to drive in anything other than Track suspension mode? You are essentially saying the controller can sense bumps so well that it will automatically briefly shift into softer ride modes for those wheels affected by road imperfections? If that is true wouldn't the ride over suddenly bumpy roads simply feel like Street?
It also sounds like, again using Track for your turning example, that the DSC/DiabloSport controller in Track mode would be in firmest base ride 100mA in all four corners, then as the turn is entered sense a difference in G forces between the inner and outer wheels (primarily more downforce on the outer wheels, less downforce on the inner wheels as the body weight rolls towards the outside of the turn) and go into Street mode settings of 400mA for the inner wheels, then go back into 100mA in all four corners as the car straightens out. Is this correct? If so, is the controller's switching to the softer inner wheel shock setting allowing greater inner wheel shock extension, and perhaps doing it quicker, than the 100mA Track setting would allow for? If so, it would keep more inner wheel downforce (and tire rubber downforce) on the ground. More inner wheel friction on the ground in a turn would improve handling (and safety) - maybe by a lot.
What happens if you start out in Street going straight and hit a bump or depression in the road? Does the controller go even softer than 400mA? If not, what would be the benefit of ever being in other than Track? If indeed Track handles sudden bumps like the two lesser firmness modes? There would seem to be no advantage, or reason, to not being in Track.
What happens if you start out in Street and start a turn? Does the controller change the outer wheels to Track settings - to 100mA - while keeping Street's 400mA on the inner wheels? If so that would be pretty great - better handling avoiding Uncle Jed's refrigerator or just carving turns always equals better safety - and it is more fun. But again, why ever select Street or Sport suspension mode if all the above is actually true? Or even mostly true?
I hope it is true. Replacing the three OEM selectable suspension modes into one super can-handle-all-ride-conditions individual wheel sensing and shock response Track mode sounds fantastic to me. Base handling in turns like Track, straight ahead ride like Street, sensing longitudinal weight shifts for better friction starts and less front end droop stops. Sign me up.
If you, or anyone else on the forum, can answer these questions we'll really be getting somewhere in understanding how this works.
Best,
Finface
This video explains it all: Diablosport suspension controller
You will need to datalog the individual sensors to gauge where/when you want to make changes.
DSC likely dyno'd the shocks, made a preliminary baseline tune, and fine tuned the controller in a car. Tuning a car to individual driving styles is very subjective. This is a 90% solution for 99% of buyers out of the box.
At best folks can sharpen up the response times sooner or delay them for more weight transfer relative to the G's seen. Assuming they have the tools and knowledge to know how. But, most people who venture into tuning this will probably end up ruining things or seeing little return or end up claiming a false positive/placebo effect.
You are over thinking this and over complicating it and muddying the waters. This box takes a linear system and makes it parabolic.
Reactions: 3
@Finface the video @motorheadmike referenced sums it all up very nicely. BTW, that is Mike in the video who developed DSC.
Reactions: 2
MotorHead Mike and Rayzazoo,
First off, I'm 99% sure I'm going to buy one of these controllers. But I haven't decided who from.
I should have watched the video in this post earlier - it's good, but again nothing I've seen offers the kind of Overview of the product I want with regard to our Challengers. I want Tom or someone from DSC to make a video or two where he unboxes the controller, installs it in the trunk, starts the car, then says, "I'm going to work so I'm selecting Street - and here is what it does in Street and why it's better than OEM Street. Then he drives on rough roads and comments about what the active suspension is doing the OEM suspension would not, does some hard stops, and quasi-hard launches, and makes some sharp turns. If you can do the "throw the car around" stuff on a road course that would be great. And he does the same for Sport and Track - IF there is a different response the controller will make dependent on those modes. I don't want to be overly critical of DSC or DiabloSport because I think you guys are engineering geniuses, but I find that some aftermarket vendors assume their potential clients are far more "in tune" (lol) with them than they are - and I think this is the case here.
Some things you (Mike from DSC) said in the video stand out and spoke to my questions.
Mike said “blending the two modes on the Viper - Touring and Sport”. Isn't this the gist of my question about a "Super Track" mode that senses and reacts so quickly (500 times/second accessing the OEM hardware is impressive!) it behaves like Street mode temporarily? It sounded like it - tuning to obtain the best blend of both worlds. For those of us who may want a true plug and play experience is there simply "The Map" that DSC or Diablo has optimized for Challengers - for the 90% who may not want to delve into the software? Or are there multiple preoptimized Maps? If there is one Map is it selectable on the UConnect screen, or always operable (like an overlay) to some degree in all three Challenger selectable suspension modes?
I poked around YouTube and caught a couple more DSC videos. There was a Porsche guy a year ago in Seattle who seemed to answer the above "best of both worlds, Super Track mode" question differently than it is blended and good to go. He compared his normal mode to his sport mode and said there was a perceivable difference. He said his normal mode was a softer ride with the controller installed, and said his sport mode was stiffer than normal like always, but it still smoothed out the road.
Mike, in talking about launch mode - you used “drag race mode” terminology. This also gets to the core of what I'm asking about in my previous posts and here. On our Dodge Challenger Hellcats we don't have a Drag Race selectable suspension mode like the Demon has on its UConnect. Street, Sport and Track is what we have - and I understand now have the three passive firmness settings. In your video showing longitudinal tuning when you set drag strip launch parameters...when would they "activate"? In one, some, or all our modes? I mentioned separating the controller's maps (if there is more than one) to marry up with our non-Demon, non-Super Sport Challenger selectable UConnect terminology because I think that would a better way to think about all of this.
In the video at the vendor show Tom explained a lot. He mentioned a Gforce signature prewritten by DSC, talked about brake pressure sensing faster than Gforce sensing, offsetting one kind of sensing against another when conflicting inputs are sensed, said active all the time, warned people can go down wrong path manually and to avoid it DSC provides "a very good base map". So I'm getting there, but you can really help if you answer my questions in this post. I liked the concept of "tune for the driver - driver reactions - "which trigger a mixed set of commands in the prewritten algorithm". I liked can tune for track and different car setups. I liked 99% of the time you see an improvement in lap times just swapping OEM for DSC controllers. A real beauty of a selling point is your controller takes a less than optimally set up car and makes them a lot better. And the concept of it automatically adjusting for rain, and getting offline on a road course.
Electronic bump stop! Can tune the shock to stop compressing to avoid rubbing with bigger diameter tires? Can you do this without changing the other functionality features of the controller?
Ever get that impression that someone will never be satisfied?
Reactions: 2
All I can say is, if you’re 99% decided to get the device, I don’t think you’ll be disappointed with DiabloSport or the DSC version on the street.
The largest difference between the two is DiabloSport is fine-tuned/programmed based upon their R&D and the DSC is fully tunable with the DSC software.
Rayzazoo,
Best,
Finface
Your over thinking it! It senses the driver inputs. For example when the brake pedal is pressed the shocks are already doing what they do to prevent the front diving. It don’t sense the weight transfer and then react. Same for turns, it anticipates the forces because you will have turned the wheel and it has the wheel position data before it senses the lateral force.
Reactions: 2
Some people just have an insatiable appetite for knowledge wink
Reactions: 2
Best,
Finface
@Finface I think the range of modes gets smaller as you go through street, sport and track suspension setups and the change at each corner gets limited in travel range.
For example:
Street: 400-100mA range (34% default @ 400mA; 41% @ 200mA; 69% @ 100mA)
Sport: 400-100mA range (18% default @ 400mA; 25% @ 200mA; 53% @ 100mA)
Track: 200-100mA range (28% default @ 200mA; 53% @ 100mA)
@7734CAT asked "@SLR Have you had a chance to do the "zero shock procedure" on the new controller, and are you still able to communicate with the suspension controller afterwards?"
I'm not messing with it (writing into it) this time unless I see or hear otherwise from Diablosport directly or on this thread. I like the way it works and appreciate them swapping it out for me. Leaving well enough alone for now.
@papnschmilees "Do we know what the range is for mA for these dampers? All three modes from what I saw only adjust from 400-100mA"
I don't, but would like to (the engineer in me). If the shock calibration table could be made more linear, I think that would be awesome. But if the shock actuation valve is like a stepper motor with only a couple positions, or if that's the range that works / matters and there's no benefit beyond the 400-100mA range, then I get why the file is built that way.
Among the 6 settings available, the three in the stock controller and the three in the Diablosport DS1000, I like the way the car drives in Diablosport's "Sport" mode for spirited street driving the best. Reviewing the file confirms to me why, a little softer in the G comfort box and otherwise the same as track. The car firms up well and is very responsive.
Reactions: 5
@Finface "Electronic bump stop! Can tune the shock to stop compressing to avoid rubbing with bigger diameter tires? Can you do this without changing the other functionality features of the controller? "
Negative. Even with the electronic valve closed, you still have the mechanical blow off stack in the shock allowing fluid to pass at a higher pressure rate. Even if you could lock it down, you wouldn't want that because the only suspension left would be the sidewall of your tire. Say goodbye to grip over bumps.
Here's a video to help you visualize this and may help with your appetite for knowledge:
SLR,
Appreciate your specific answer, and the visualization video.
I understand the fluid flows back and forth, dampening the bumps, and the video shows the electronic signal flow from G sensors so this is demonstrating DSC's "active dampening", or "active suspension" technology, with Bilstein shocks versus the OEM controller's passive three firmness settings with Bilstein shocks. Nice sound track too.
Good appetizer. Still hungry, let's open a bar tab...I forsee a building thirst for knowledge to go along with my appetite grin.
I don't think I'm being unreasonable asking my questions. You and some others are talking about customized programming. Yet, no where that I've found is there basic descriptive information about how this controller interfaces with the car's UConnect, i.e., something as simple as "does the screen even look the same?". You may scoff at that observation because you've seen the screen, but really, if you don't know you don't know. This link below says nearly 57,000 Hellcats with the Bilstein shocks needed to work with the DSC controller have been sold since 2015. That's the market for this controller, and if I was running either DSC or DiabloSport I wouldn't neglect to have comprehensive basic information about it available to curious potential customers on my websites.
Look, I get it. Brand new product for the Hellcat, proven on other cars, we've got some positive testimonials. I'm skeptical by nature and want more information not yet available. Don't blame me for asking (not that you have).
To get more basic background information on my 2019 Red Eye's suspension I googled "adaptive suspension", which is the hype about my car's standard equipment. "Adaptive Suspension" sure sounds like what the DSC product delivers and calls "Active Suspension" - but it's not. It's just three levels of selectable firmness as Rayzazoo posted, right? It's not "adapting" to anything other than my finger touching the UConnect.
So the marketing, and the hype, and the thing I pointed out to Motorheadmike about the trap I think engineers can fall into - assuming their customers know as much as they do - persist.
Like I said, this controller if it works as people say it does, and the software doesn't result in problems with the car (so many times when I've bought great sounding third party software, or hardware, for my Apple computers compatibility issues surfaced so I'm leery), would be about the best thing since sliced bread.
Thanks again for your reply.
Reactions: 2
@Finface, no difference between the OE and Diablosport boxes on the user interface side. Both boxes communicate with the car / ECU / CAN bus system to get their input and adjust through your touch screen.
Reactions: 3
All the magic is in the controller programming.
Dodge does a lazy job of programming the Mag ride controller.
This new controller use the functionality of the shocks much better, takes advantage of their ability to go from firm to soft in an instant and recalibrates all modes.
When launching the car, it will make the shocks act as close to a 50/50 rear, 90/10 front that you can get. Then when you dive into the return road at the end of the track it will firm up the shocks for reduced body roll and improved cornering.
For more info, read some reviews of the DSC controller from GTR and Corvette and Mustang owners who have used them. I have yet to find anyone that regretted the purchase.
FWIW, GM does a MUCH better job of programming their magride systems, and when you see how much the Vette/Camaro guys rave about what the new controler does it should make you wonder how much better your set up can actually be.
What is your refund policy if your are not happy with the product?
"You may return the new, unused part"...meaning you can't install it, and then drive around to know if you like it?
But you can look at it and return it?
Who writes these things?
Is this going to kill me?
Gadget Gas Rectangle Audio equipment Electronic device
Reactions: 4
I am still living. I touched it and even plugged it in. The Redeye has some new spots on it, but I am still okay.
Reactions: 4
Mike,
It's nuts how California has gone overboard with cancer warnings. Proposition 65 was one of those things that got voted on after a petition obtained enough names, and it passed in a general election. You can't go anywhere in California without seeing big cancer warning signs. They're in the jetways at airports - I guess because some diesel and kerosene fumes might be evident (I'm with Lieutenant Colonel William "Bill" Kilgore, 1st Squadron, 9th Cavalry Regiment commander, in Apocalypse Now, who famously said, "I love the smell of napalm in the morning!". They even have signs outside restaurants and bars warning of cancer. Why I have no idea.
Best,
Finface
Known to the state of cancer to cause California.
Reactions: 3
The stupidity of this is that there are things public should be aware of (say, some pesticides), but put this warning everywhere, and people will stop paying attention even when they actually should. Which defeats the purpose of the Proposition 65...
Reactions: 4
