I've looked through several threads on here and also reviewed the DodgeGarage.com differential fluid change procedure. Nobody mentions thread sealant or teflon tape when replacing the plugs. I noticed that the threads on my plugs do not have any indication of having a sealant on them.
So with all that said, am I correct with assuming they do not need any thread sealant? I did see several posts about torqueing to 26 ft-lbs.
It does look like the plug has a bevel under the head of the plug that is probably making them seal. Just a guess though from my observation.
Thanks,
Dean
Thanks,
Dean
