1 - 20 of 20 Posts
Challenger SRT Hellcat 6MT
I'm going to replace stock arms to tighten the back of my car; I will also install the BMR cradle lockout kit.
Here is a question: why would I want to spend extra on adjustable arms? The car never sees a track, stock hight. Current camber appears to be close to zero (eyeballing it); rear tires wear exceptionally even (which is good, given the silly price of those PS4S 315's ).
2015 Charger SRT Hellcat
There is NO downside to having adjustable arms on back (or front for that matter) I chose AAD unequivocally but opinions and combinations vary.
Get it solidly aligned and you as come to the same realization I did that the car drives more true than ever
There is NO downside to having adjustable arms...
Mucho dinero... I want to know if it makes sense. The car drives true and straight and the tire wear is perfect as it is. I don't want to spend money on adjustable arms if I end up setting the same angles as before. Also, I really don't want to bring it to a dealer for alignment unless I have to.
Looks like you’ve already answered your own question…twice.
2020 Hellcat Redeye Widebody
UP to you........on my 4wd's, I go with double adjustable, but ONLY when I have to replace a stock arm, and then in pairs.
If nothing is wrong, then it makes no sense spending money on something that isn't needed yet.
‘16 A8 Shaker
There is no for argument… just against.
It would sorta be like buying a bead lock wheel for a slow drag car. I said sorta cuz that actually does the opposite of what they are trying to do and yer not trying to do anything
Discussion Starter · #8 ·
A possible argument for adjustable arms would look like that: I (or someone I know) installed fixed length aftermarket arms and they were not the same length as stock, so now my geometry is messed up... Or: the stock camber is wrong (you know it because XXX), so you want to change it. Or something else.
BTW, if I go for fixed length arms, it's probably going to be the BMR ones.
I installed them because I slightly lowered the rear and didn't want any boot tears just to be on the safe side. I did not lower the front though just to keep the geometry I just want to level out the car
‘16 A8 Shaker
Yeah I did the same thing zeroing the camber with one adjustable link per side but his isn’t lowered and he isn’t getting the adjustable arms. Makes zero sense to me but guys do stuff all the time on here that I do not understand. Race brace. DIRS. Etc. No idea what part really does but put $500 on a credit card without thinking about it
frame it tub it
Discussion Starter · #12 ·
What exactly makes zero sense to you? Getting arms with less flexible bushings? Asking if there is a good reason to spend extra on adjustable arms? No lowering the car? People write stuff all the time on here that I do not understand...
‘16 A8 Shaker
I would not lock out the cradle in a street car. I think you are wasting your time and money.
Same with the arms
There are threads on here with them failing from aggressive cornering, and threads about binding issues too
Is the diff already locked? That should be number 1 on everyone’s list. Unless they are just putting around and never turn off the tc/esc. How long do those all season 305’s last you?
Discussion Starter · #14 ·
Same with the arms
It's is not a real lockout, even though they call it this way: it's actually a milder setup than polyurethane cradle bushings (the rubber bushings stay, but they are very restricted in their movement, so there is only minimal increase in NHV, but the back end in more controlled-- this is according to pretty much everyone who installed the kit).
As for the arms, less squishy bushings should make the geometry more controllable under hard cornering and hard acceleration. I don't need a track to feel the back waiving left and right under hard acceleration, and I can live without the occasional wheel hop. Based on what most people who actually did this mod have to say, I expect improvements in this area.
Which ones are you referring to? BMR adjustable? I'm not even considering them...
^ yup. Ponderous.
1 - 20 of 20 Posts
