11.4 is not quite 10.9Shit I ran that same MPH in my 21 a10 ZL1 on a 17" MT ET street SS a few days ago at bradenton MP in like 4k DA, stone stock other than the tire.
I said MPh.11.4 is not quite 10.9
Sent from my SM-G781V using Tapatalk
Yeah I was wondering about low traps. RE Chargers usually trap 127-129 from what I see .I said MPh.
He didn’t seem to have a traction problem with the Dr so I don’t think the burnout was a problem. I don’t even do burnouts on my DRs at the track. My ET street SS’s stick like glue at 20psi no burnout.Don't the experts say NOT to heat up street tires? I realize it wouldn't matter much, but just for info. Secondly, his burnouts with the DRs seemed a little soft. I have the MT Street R so would like to know how much to smoke them.
Nice lightI said MPh.
I was focusing on trying to get the exact RPM to launch at and make sure it was stable before hitting it. But thanks. No need to try and race the Plaid in the other lane anyway. It was T&T and if you know anything about drag racing, then you'd know RT has no effect on ET.Nice light
Thanks.He didn’t seem to have a traction problem with the Dr so I don’t think the burnout was a problem. I don’t even do burnouts on my DRs at the track. My ET street SS’s stick like glue at 20psi no burnout.
What's even crazier to me is that the red eye was able to run almost as quick of an ET on STOCK tires vs your drag radial pass. And once it had drag radials would have put a bus length on you. That's what surprised me in your little comparison here. That said, the mph is definitely lower than the typical 128-131mph I usually see red eyes run stock.Shit I ran that same MPH in my 21 a10 ZL1 on a 17" MT ET street SS a few days ago at bradenton MP in like 4k DA, stone stock other than the tire.
What shouldn’t surprise you is the HP difference. My 650 to the RE 797. Lol. That pretty much tells the tail in the ET difference. But baffles is how slow of a MPH that shitbox charger managed.What's even crazier to me is that the red eye was able to run almost as quick of an ET on STOCK tires vs your drag radial pass. And once it had drag radials would have put a bus length on you. That's what surprised me in your little comparison here.
Lets see here, the Charger is what 800-900 lbs. heavier than your Crapmaro? Might have something to do with the trap speed.What shouldn’t surprise you is the HP difference. My 650 to the RE 797. Lol. That pretty much tells the tail in the ET difference. But baffles is how slow of a MPH that shitbox charger managed.
See the problem you have is I actually owned one of those charger POS's. I actually hated it enough to go back to the crapmaro. And much happier for it. I can add power, you can unmake yours a piece of trash.Lets see here, the Charger is what 800-900 lbs. heavier than your Crapmaro? Might have something to do with the trap speed.
Yeah man and I owned a tiny blower GM product that burned oil and needed a blower replacement, headlight replacement, steering column replacement, and sunroof replacement by the time it was 3 years old.See the problem you have is I actually owned one of those charger POS's. I actually hated it enough to go back to the crapmaro. And much happier for it. I can add power, you can unmake yours a piece of trash.
In reality no one really cares what your Camaro runs. Go brag about your mid 11 somewhere else, that 1320 runs that na.See the problem you have is I actually owned one of those charger POS's. I actually hated it enough to go back to the crapmaro. And much happier for it. I can add power, you can unmake yours a piece of trash.
