Finally a drop in 750+ hp fuel pump module for Hemi applications is available from @deatschwerks for 2006-2021 models.
Shop DW Fuel Systems - - > DeatschWerks
Powered by the 415LPH DW400 pump
• Supports 750+ HP (Pump Gas, N/A, Crank)
• Engineered for 5.7, 6.1, and 6.4L engines
• Retains all O module functionality including:
• Plug-n-play harness connector
• Fuel level sender
• Fuel surge bucket
• Works with 2006-16 and 2017-21 Wiring Harness
• Compatible with pump gas, race fuel, and e85
All DeatschWerks Fuel Injectors and pumps feature E85 compatibility, Flow rates and set balancing in-house by DeatschWerks, Flow balanced to within 1-2% (flow report included), Excellent spray pattern and atomization for optimized idle and tuning, Technical assistance and tuning data available via phone or email and 3-year comprehensive warranty. The new injector flows 1700cc/min at 100 bar of fuel pressure which is more than a 30% increase in flow over the stock EcoBoost injectors. The patent-pending process used in this injector allows for increased flow while retaining the OE spray pattern, which maximizes fuel economy, emissions, and drivability.
Beefcakeracing.com
1-855-827-7223
#deatschwerks #fuelpump #hemi #dodge #dodgecharger #dodgechallenger #srtaddicts #srt392 #dw400 #dw400pumpmodule #dwpumps
• Fuel level sender
• Fuel surge bucket
