Really... they told me they had nothing. I assume it was the front adapter plate they swapped out? Did you measure the thickness difference between the two? Just curious what it was... if I had another 1/8" it would then be in the zone!I had the same problem And it setup a drone through the car talked to DSS and they sent me a smaller rear driveshaft adapter installed and all was good
It's nice when a company stand behind their product but I don't want to have problems & hassles to begin with taking it in & out & shipping it back waiting on it , that's a bunch of BS. They have been doing this long enough to get it rite & I still here of issues or vibration. That's why I went with Wiles Racing DS, no issues what so ever, if I didn't put it in I wouldn't know it was there, no clearance issues cause it's 3.5" aluminum with carbon fiber insert for more strength, it has NO adaptors direct bolt in, 1350 u joints at each end to articulate if it needs to & it's the same price or cheaper. Mr. Wiles also stands behind his DS's if he ever has to. Good luck guy's.Thx WNY Cat... I remember that thread but the search doesn't always pull those threads up so I couldn't find it. I actually replied 3 or 4 times on that post. I just read the whole thing again... seems very similar to my situation... just a tad tight but still not binding. We'll see how she runs at the track tonight.Sounds like the DSS worked with you pretty good... while a pain... at least they did what was right, which makes me feel pretty good about my DS.
Get your $money back + expenses if you can & call Wiles Racing Shafts & you'll have no more issues, you won't be sorry.Well Guys... The unbelievable happened tonight. My CF DS exploded on the 5th pass.Not sure what happened or why but what a giant PITA!
Car is stuck at the track I'll have to pick it up tomorrow. I'm gonna give DSS a call in the morning. If you've ever have this happen... you can't even shut the car off. The issue is the tail shaft was still spinning even in neutral... when you put it in park it won't engage the park lock because the transmission senses the tail shaft still spinning. Because the transmission was still spinning, it wouldn't allow me to even open the trunk. We pushed it to the pits and the only way to shut it off was to pull one of the relays from under the hood. I'll update as I go... maybe start a new thread. Bummer!
You did not know I double as a fortune teller? See post #4 above. Now, I will imagine when you drag its ugly azz out of your car it will look just like this....Well Guys... The unbelievable happened tonight. My CF DS exploded on the 5th pass.Not sure what happened or why but what a giant PITA!
I'm no expert, but since you have a carbon fiber DS, then there should be no damage to the underside of your car. When it fails, it shreds into fibers.Well DGatzby... you must be a physic or something. I'm not sure what the shaft looks like I just know there was a lot of it on the ground. Now the fun starts as I've got to figure out a way to get it home. I have a truck and enclosed trailer but no winch to pull it on the trailer. Naturally being a weekday everyone is working... could you use your physic abilities to load it for me! I called DSS and they were very good to speak with and gave me a RMA. We'll see where this goes. How much damage was there to the underside of your car?
Matter of fact I was just viewing the underside in detail this morning at QA1. Everything came out fine on mine, I would expect yours looks a lot like the picture I posted. Yep, million pieces were on the ground. What I did was simply towed it to a nearby good shop, brought my OEM DS to them and had it reinstalled to get it back on the road. The only thing we see is the insulation up in front of the silver heat shield seems to be deteriorating. Don't know if it started last year when it busted or it is just having a bad life in the Hellcat.I'm no expert, but since you have a carbon fiber DS, then there should be no damage to the underside of your car. When it fails, it shreds into fibers.
It is amazing how many people stay loyal with a company that continues to have issues with one thing or another ? Sure they will try to correct issues , their suckering in new customers . Why don't they fix all their issues b4 they sell or ship any ? Insanity is doing the same thing over & over & expecting a different result ! Call Wiles Racing Shafts & be done.I had that issue, they said my Hellcat was a unicorn. I say BS. I busted my FIRST DSS CF shaft at the starting line at the strip. They rub and if you give it hell in a dead hook it could happen to you. The second one fit like yours, it was too long, and we sent it back. QA1 will be releasing their 3.25" CF shaft soon. I have been attempting to make their prototype unit fail for about two months now. It is badazz.
Agreed. The other option soon will be QA1 at 3.25". They gave mine the final once over this morning. I think they will have an announcement soon.It is amazing how many people stay loyal with a company that continues to have issues with one thing or another ? Sure they will try to correct issues , their suckering in new customers . Why don't they fix all their issues b4 they sell or ship any ? Insanity is doing the same thing over & over & expecting a different result ! Call Wiles Racing Shafts & be done.
Good to see that there is other better options out there & everyone needs to take the blinders & rose colored glasses off & stop following the herd sometimes. Especially when there is ongoing issues !Agreed. The other option soon will be QA1 at 3.25". They gave mine the final once over this morning. I think they will have an announcement soon.
