1 - 3 of 3 Posts
Doing my first oil change on my DDHC and the oil filter drain plug and filter is WAY easier to access compared to my ‘16 Charger.
But does anyone know where the oil cooler drain plug is on these bad boys?
Thanks!
I ended up doing the access panel like the Trackhawk folks do. The valence for the Durango is a bit different, but I’ve included pictures of my job in case anyone wants to tackle this for themselves. Super easy and pulled about 1/2 quart out of the cooler.
Used some .025 Aluminum sheet I had around my shop. Used Dodge push pins to locate it. The aces hole is just large enough to get a 1/4” drive ratchet with a 15mm socket in there.
Tire Wheel Automotive tire Hood Light
Land vehicle Tire Wheel Motor vehicle White
Land vehicle Tire Automotive tire Hood Wheel
Barware Fluid Liquid Automotive lighting Alcoholic beverage
Automotive tire Light Automotive design Fixture Hood
Hood Automotive lighting Automotive design Bumper Carbon
1 - 3 of 3 Posts
