1 - 15 of 15 Posts
· FCA Official
My understanding of it is that it will be an enhanced valet mode, not anti-theft. Limiting speed to less than 5 mph and lower rpm than current valet mode. Nothing to overcome a repeater box which has been used on all manufacturers that use proximity keyless entry. Anyone care to elaborate? @DodgeCares
· FCA Official
Rob, what is the late 3rd quarter? End of October?
Hi HemiMetal,
Hope you have been well. We expect late in the fall season.
Rob
Dodge Cares
Reactions: HemiMetal
· FCA Official
Greetings moparbrad,
The software upgrade applies second-level vehicle security encryption via Uconnect 4C infotainment system. Using owner’s existing four-digit security code (PIN) from their Mopar.com/Uconnect account , feature limits vehicle’s engine speed to idle (675 rpm) and helps prevent auto theft. Double encryption has become common on consumer online accounts and adds a second layer of owner protection against vehicle theft.
Rob
Dodge Cares
So are you saying that a repeater box that duplicates your existing key would bypass Valet mode? I would think that Valet mode would stay on if it sees the same key. Would creating a new key (like where they plug into your OBD port) also bypass the Valet mode?
The next question is will the new 2-factor authentication be reset like Valet mode does when the battery is disconnected? @DodgeCares
Reactions: ScLeCo
1 - 15 of 15 Posts
