1 - 11 of 11 Posts
Considering(and probably getting on ) the waiting list for the 1” spacers from FI. Anyone know if they then cause the supercharger lid to contact the hood?
Also what belt should be used with the 1” spacer and a 2.90 upper
2019 Hellcat M6
I bought a pair for my build, but have not installed them yet. I asked FI and they said no one has reported issues with the hood clearance or the fuel line and the 1" spacers. They also told me I need a 50mm longer belt, which from searching gates site the Gates K060598HD is the closest over stock length. Hopefully someone who has done it chimes in on this and can confirm.
Discussion Starter · #4 ·
Last I heard he wasn't making any more. On a side note my blower rubs the hood liner with just the regular spacers, but it's a Charger, you Challenger guys may have more room.
This site says when they get 20 people they will make a batch.
Your stock blower with the lower spacers hits your hood?!?! Hmmm
Reactions: dragrcr
I have the spacers and blanket kit now. Running the incognito with a 2.79 upper and the belt is a Gates 100594 micro v. Not sure that is the same as what you would be running in the cars. Normally it would be a Gates 100576 for stock for me.
Discussion Starter · #6 ·
Are you using the 1” spacers?
It rubs on the heat liner/sound liner yes. If I took that off I suppose I'd have about 1/8 to 1/4 inch clearance.
I'm not sure how much room the challenger has.
Kirk told me some guys can run them no problem and some can't. 🤷‍♂️
I’m more worried about putting stress on the stock fuel feed line - Fi still hasn’t answered any questions about it besides “people run them with no issues”
You also have to consider the stress you are putting on your snout, bearing housing and other things that are attached to the blower. Lot to look at and consider.
1 - 11 of 11 Posts
