1 - 5 of 5 Posts
Did a search and really only finding old threads on them mainly with early feedback on them. Seems like several people have been running them. About to pull the trigger and wanting to see if those long time users are still happy and would do them again. My IAT is constantly 150+ (even in only 80-90 degree days) as traffic sucks royally and I think my SC is just heat soaking. My intercooler Temps are normally pretty good (20 or so degrees above ambient) but IAT never really comes back close to that after sitting in traffic for a while.
'23 Redeye Jailbreak
IAT is not very important on our cars. The charge air is after-cooled before going into the intake runners. The temp the I/C coolant is running at is the marker that can be easily read that more aligns with what the PCM is using to mix the fuel ratio.
Good to know. Thought timing was based off IAT's from those sensors. So I guess the concensus now is not really worth it? When I pull the SC for a pulley change I'll install a heat shield blanket and skip the plates if that's the case.
2018 Trackhawk "not stock"
Buy the cometic fiber gasket, get rid of the aluminum rubber ones. Prevents some heat soak from the heads.
About 50.00 total
A Van Down by the River
IAT is important because the PCM starts pulling timing around 140F if I recall. The blower spacers and blanket will lower your IATs about 10-12F on average.
1 - 5 of 5 Posts
