1 - 20 of 21 Posts
2018 Charger Hellcat Granite
Here are a couple pictures after cleaning the cat up. I am running 315/35/20 rear and 275/40/20 front. I had 305’s on the stock rear wheels and the 315 with offset actually clears better. Love this setup so far.
Boi, if I can get the same sidewall angle (close to vertical) from some Nittos in 315, I want some Motivos in that size for my next set on the stock rims.
Discussion Starter · #5 ·
Just to be clear, these are FR77 wheels, 20x11 rear and 20x9.5 front. The 305’s I put on my stock wheels had a little too much bulge for my liking but never had an issue.
How well do they hook up? I run the same tire currently and I’m debating to go to the drag radials version but I’m thinking 315s will hook.
You may have some issues with the 11" wheel. I'm using the Factory Repros 10 1/2", 25MM offset, and it is close; 1/4" passenger side, w/o spacers. I am using the PS 4S which people say are wider than most.
Discussion Starter · #12 ·
Light years better than anything I have had before but they aren’t going to hold from a dig unless they are really toasty. They hold good from 30mph or so.
Discussion Starter · #13 ·
oops. Drat. They are 40 pound each, yes, the 20x11's?
No clue on the weight honestly. I’m not at the weight shedding stage. I’m ok with a big heavy street car with lots of power and looks good 😁
Discussion Starter · #14 ·
I have plenty of clearance with these. I have heard the PS run wide so that might be the difference.
Thank you for this this thread and your follow up questions! I have these wheels in my cart now. Just trying to decide on the drag Radial version of the GenII.
looks clean. I like it.:love:
Reactions: GreySmoke13
Discussion Starter · #17 ·
Sure thing. I did a bunch of research before pulling the trigger with most of that coming in this forum for people that posted their experience. Glad to give back a little.
1 - 20 of 21 Posts
