Any feedback on using these tires on the front skinny Demon wheels?
Mickey Thompson 6688 Mickey Thompson Sportsman S/R Tires | Summit Racing
Thank you. I’ll order up a pair of these today. Just to clarify…. Are you using 4.5” wide Demon wheels?I love them. I had them on my '19 REWB and now I am using them on my '21 SS. I set them to 65psi for the 35 minute drive to the track. Pump them them up to 85psi for the track runs and then back down to 65psi for the ride home.
Sweet, thanks!I have them on my 18X5 Forgestar wheels at the moment, but they will fit the Demon wheels. They are good down to a 4.0 wheel.
They are an excellent tire and will fit that wheel without any issues. I left mine at 75 PSI all the time.Sweet, thanks!
Thanks! I got a set coming!They are an excellent tire and will fit that wheel without any issues. I left mine at 75 PSI all the time.
Those psi numbers seem extremely high, no issue on the tires being overinflated??I love them. I had them on my '19 REWB and now I am using them on my '21 SS. I set them to 65psi for the 35 minute drive to the track. Pump them them up to 85psi for the track runs and then back down to 65psi for the ride home.
The front runners I use show a max pressure of 35psi. This seems odd tooThey are an excellent tire and will fit that wheel without any issues. I left mine at 75 PSI all the time.
It depends on the tire. The MT front runner is made for heavier cars and is used as a road tire for the old time hot rods that is why it has a max psi of 95psi. Where as the M&H front runners are a drag only tire and have a much lower max psi I think around 40psi. The MT also weighs more then the M&H and can handle a heavier load.Those psi numbers seem extremely high, no issue on the tires being overinflated??
Thanks for that info.It depends on the tire. The MT front runner is made for heavier cars and is used as a road tire for the old time hot rods that is why it has a max psi of 95psi. Where as the M&H front runners are a drag only tire and have a much lower max psi I think around 40psi. The MT also weighs more then the M&H and can handle a heavier load.
Thanks for that info. I have MH and at the 35 they specify the tire seems to appear low. That was why i was wondering. I did not realize the differences between MT and MHIt depends on the tire. The MT front runner is made for heavier cars and is used as a road tire for the old time hot rods that is why it has a max psi of 95psi. Where as the M&H front runners are a drag only tire and have a much lower max psi I think around 40psi. The MT also weighs more then the M&H and can handle a heavier load.
I had a set of the M&H front runners on my '19 REWB and they always looked like they were low. When I drove the car at the track I felt a lot of resistance like my brakes were locked up from all of the drag from the tires looking flat. On a lighter narrow body the M&H aren't so bad, but the heavier WB's max out the load allowed for those tires.Thanks for that info.
I was referring to the suspension components of the WB RE's, SS's and Demons. A lot off the suspension parts are beefier on these certain models making them weigh more then the NB's.Those plastic flares are really heavy
