I’m around 900 to the wheels on e85Skinnies with Et Fronts, not SRs, 100% will net you a couple of tenths, and if you want to maximize ET loose the beadlocks for stock power, save you another 12lbs rotating mass.
Yeah I'd keep the beadlocks at that point.I’m around 900 to the wheels on e85
Going with the lightest wheels and tires that you feel comfortable affording is the FIRST thing that should be done.Alright guys, last few things before hitting the track. So close I can smell the ignite. I’m running 17x10 f14 beadlocks with Mickey 315/50r17 radials. I have a diff brace. I installed rear cradle lockout. Looking at getting my matching 18x6 front runners for the car, or going with wheel hop eliminator kit from AAD (about the same money with tires). Passenger seat and rear seats will be out of the car, and that’s about all the weight I’m shaving off besides the weight difference in the rear drag setup, which isn’t much. What do you guys will net me better gains on the strip? Wheel hop eliminator, or front runners?
Car tracks straight as an arrow ever since I locked the cradle out, haven’t noticed any wheel hopDepends on if you are having wheel hop an d traction issues. Front won’t help if you can’t leave the starting line
I don’t remember the setup but track tuning is always an optionI’ll be talking to you soon @Jonx96, still trying to hunt down a dyno
Not that I have found testing.Do the skinnies legit really make a difference in cutting a couple of tenths?
Mines modestly modified, shaving weight down. The skinnies got me a lot of weight off the front, less rotational mass/dragNot that I have found testing.
Maybe .05-.08 with a light tire.
On a stock car
Can't speak to those guys running so called "stock" cars that have tunes, driveshafts,rotors, exhaust ECT, but yeah they're stock 🤣🤣🤨.I've had some feedback from folks at the track saying they didn't really notice or weren't quite exactly sure if the skinnies made a difference for them. I was trying to justify if they were worth the coin or not.
Granted they weren't running the ET fronts though as they had the SR's up front.
Especially with the ET front runner tires you mentioned?
Did you add those tires on to the car without doing anything else to the vehicle to be able to judge what you run with the skinnies alone?
If I remember correctly it was almost 50lbs savings from the stock wheels to dark stars and M&H fronts. I tried it on 3 occasions when my car was stock. Sure I could say hey look I gained a tenth and a half. In reality running 3 passes on stock fronts then switching to the skinnies for 3 or 4 passes and switching back for another pass or two. Has averaged out to about .08. I tried it this year once with 3passes then 3 passes and it was .08 on average.Mines modestly modified, shaving weight down. The skinnies got me a lot of weight off the front, less rotational mass/drag
