1 - 3 of 3 Posts
Have a 2019 Redeye with 6000 miles on it. The fuel gauge is not moving from 3/4. I got p0461 engine code then 2 minutes later was out of gas. Anyone know or have this issue? Assuming it’s sending unit but checking here before pulling it apart. Thanks
There have been some reports of Challengers with wiring encroached under the rear seat. Visually follow the wiring from the tank to see if you see any wiring issues. If it goes into the body near the rear seat, you'll to pull the rear seat cushion out to continue your visual inspection.
You can also Search the Forums for Challenger Rear Seat/Wiring issues.
1 - 3 of 3 Posts
