1 - 13 of 13 Posts
What should my initial fuel pressure be set at?
428C.I. whipped 4.5 180 mm t.b
Fore dual pump with return system and boost reference.
the pressure is up to your tuner , 4 bar or 3 bar would be fine .
Discussion Starter #3
Not sure what you mean. The car only has 2 bar sensors.
60 psi or 48 , again it's up to your tuner
Pardon my ignorance. I have not modded my Hellcat yet. Is the fuel pressure regulator not boost referenced?
in the aftermarket fuel system yes . but base line have to be set
Stock pressure is 58psi (400 kpa). Cant remember the minimum needed for the fuel transfer function in the tank but stock Fuel pressure is set at 58psi.
I have a triple pump setup and it's set at 58 psi while referenced to regulator at idle
Banned
What kind of problems are you having? My fuel system from Curt at Injected is working flawlessly.
Thanks Guys.
On a fore system I typically run them @ 4 bar boost referenced as that is what they are stock but I would recommend asking your tuner.
Banned
Curt's fuel system is returnless and it is plug and play. Best fuel system for our Hellcats hands down. Plus the price is right. I would recommend you contact him if you're looking to upgrade your fuel system.
Awesome thanks
Sent from my STV100-3 using Tapatalk
1 - 13 of 13 Posts
