I bought a Hellcat that has had some work.
I have confirmed that it has a 2.65 pulley with a anti slip tensioner and a pinned crank. The intake, and the mid muffler is gone along with the possibility that the cats are gone too. All this with a HP Tune. That's what I have confirmed so far.
Now, I know it runs well on 93oct and was told that if I ever plan on taking it to the track and hammering on it, to run 100oct. Does that sound right or would a mix be closer to what it really needs. Perhaps closer to 95 or 98 oct?
Next question, I know the car can still run 91 just not happily and you really need to keep out of the boost when you do. If I plan on traveling with the car across states that don't offer 93 or higher. Will it be okay? And how can I switch between fuels without pissing off the knock sensor? Say I drive to across a couple of states on 91 and then get there and want to show it off with some 100oct. Then after put it back on 91 for the return trip
Thanks in advance. Appreciate realty expirenced and well seasoned advice here.
