The down side is having to go to the trouble of removing the fuse or relay after use and then installing these before use.Where is the fuse box located for this fuse and is there any downside to pulling this fuse from M-F each week, since i only drive the car on weekends?
Thx
Yes, this. Even then, if the starter is cranking but the engine isn't turning over, they'll still probably swap out fuses anyway. But any time added to a potential theft is always in your favor.My advice, gut out a spare relay and put it in the place of the good relay. If you leave an empty spot, these thieves will figure out that the relay is missing if they have enough time, and I wouldn't doubt that the pros will be carrying spares.
Be patient, mine came 3 weeks ago, took 15 weeksThis is a good temporary measure and adds to any security you have on the car. If you’re going to pull relays, you should definitely consider adding a kill switch. It’s on my list of to-do’s when my DDHC arrives (if it ever gets built).
I think a & $10 kill switch would be much handier. And a garage or wait.This is a good anti-theft idea for anyone that has to leave their car outside
The wait is grueling. I ordered on 6/28 so I’m expecting to be one of the last off the line this year.Be patient, mine came 3 weeks ago, took 15 weeks
